Update 5 - FME 2021 Plugin
sisNET CE supports the use of FME 2021 since Update 5. The plugin is available under c:\Program Files\Bentley\OpenUtilities sisNET CONNECT Edition\OpenUtilitiesSisnet\Addons\.
