| Product(s): | ProStructures (ProConcrete) | ||
| Area: | General | ||
| Subarea: | N/A | ||
This wiki explains how one can rename the "ConcreteSolidReference".
1. Select the "ConcreteSolidReference" object and Hold Right Click then select the Structural Properties.
2. In the Concrete Solid Reference Properties dialog, go to Partlist Data > Data and here in the Name field you can change the name (e.g., ABC). Once done click on the OK button.
Now, the name has been renamed and the same we can check in the tooltip.
