| Area: | Import/Export | ||
| Subarea: | DWG | ||
This section contains wikis related to the DWG Import/Export options from the ProStructures CONNECT Edition.
DWG is the proprietary native file format for AutoCAD, one of the most popular computer-assisted design (CAD) packages. The format is maintained by AutoDesk. DWG is a compact binary format that stores and describes the content of 2D and 3D design data and metadata.
Please follow the below links for more information about DWG.
