How to Turn off Hatching Lines for OpenPlant Isometrics Manager-v8i
 Product(s):OpenPlant Isometrics Manager
 Version(s):08.11.11.87 - SS6
 Environment: Windows 7 (64 bit)
 Area: Settings/Attributes
 Original Author:Michelle Saucier, Bentley Product Advantage Group
In OpenPlant Isometrics Manager, to turn off Hatching lines for OpenPlant Isometrics Manager. It has been included with new release of OpenPlant Isometrics Manager & are available under node - Rolling Offset Depiction. Below are the steps to get the desired pattern.
  1. Launch OpenPlant Isometrics Manager.
  2. Select Project unit, say OPModeler_Imperial here and click OK.
  3. In Isometrics Configuration>Isometric Style>Rolling Offset Depiction>Hatch Properties>Angle Annotation.
  4. In Isometrics Configuration>Isometric Style>Rolling Offset Depiction>Hatch Properties. See default settings dialog below.
  5. Change Spacing to 0, and uncheck "Show right Angle Symbol". Save and close.
  6. Generate New ISO Sheet, this will eliminate both the hatching lines and right angle symbol from the ISO Sheet.
communities.bentley.com/.../13393.settingsattributes-openplant-isometrics-manager
Comments or Corrections?
