| Product(s): | Promis.e CONNECT Edition | ||
| Version(s): | 10.00.XX.XX to 10.10.XX.XX | ||
| Environment: | NA | ||
| Area: | Database Platform Support | ||
| Subarea: | SQL Permission |
What are the minimum permissions required for a user to successfully connect and use a SQL project database with Promis.e CONNECT?
This article is to help New Users or SQL/Database Administrators to create/update SQL Server Login for users to connect with Promis.e CONNECT Project Database.
1. In SQL Server Management Studio, connect to the server where the Promis.e CONNECT Project Database is located. If you dont have SQL Server Management Studio(SSMS) installed you can download and install it from below link.
learn.microsoft.com/.../download-sql-server-management-studio-ssms
2. In the Object Explorer tree expand Security > Logins right click > New Login if the user dose not already have a login and go to step 4. If the Login for the user exists then go to Step 3.
3. For the user who already has a login Expand Logins > select the User and Right Click > Properties.
4. Then if the user account new select all the required details in General and then go to Server Roles and check Public.
5. On the User Mapping page, select the database used by the software in the Database column. Specify "dbo" in the Default Schema column.
6. In the User Mapping's "Database role membership for" check the below options and click OK.
db.datareader
db.datawriter
or
db.owner
learn.microsoft.com/.../create-a-login
| Original Author: | Satish Saptasagar |
