To Display Dimensions of Gasket and Valve Separately- v8i
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.11.87
Environment:Windows 7 (64 bit)
Area:Settings/Attributes
Subarea:-
Original Author: Michelle Saucier, Bentley Product Advantage Group
During isometrics generation in OpenPlant Isometrics Manager, below steps provides information on dimensioning of Gasket and Valve Separately.
Problem Description
While generating Isometric Sheet, User requires that the Gasket and Valve are dimensioned Separately.
Steps to Resolve
  1. Launch OpenPlant Isometrics Manager.
  2. Under the Tools Tab> Configurations> Isometric Styles> uncheck (Combine Gasket with Flange).
  3. Check the box ( Dimension Gasket ).
  4. Save Changes and close Configuration Manager and regenerate Iso Sheet.
communities.bentley.com/.../13393.settingsattributes-openplant-isometrics-manager
communities.bentley.com/.../4351.openplant-isometrics-manager
communities.bentley.com/.../20482.to-dimension-valve-with-gasket-in-openplant-isometric-manager
Comments or Corrections?
