| Product(s): | ProSteel |
| Area: | Structural Objects |
| Subarea: | General |
| Original Author: | Vyanktesh Nama, Bentley Global Technical Support |
This wiki explains how to delete Ladder, but the process is same for deleting other Structural Objects such as Handrail and Stair etc.
1. Select the Structural Line.
2. Drag it bit aside, by doing this all objects along with Structural Line gets selected.
3. Now, hold right click and from the Context Menu, select Delete Element.
In this way, we can delete the Ladder or other Structural Objects.
