| Area: | MicroStation Basics | ||
| Subarea: | Viewing Designs | ||
In the below image, we have turned off the level PS_PLATE and plates get disappeared only in the View 1 not in all the views window. So, in this wiki, we are going to learn how to apply Level Display settings to all open views.
1. Open Level Display dialog and set your required settings for the level display. Let's consider the above example where we turned off the level PS_PLATE.
2. Now, left-click on the Apply To Open Views button to apply the level display settings to all open views.
3. In the below image, we can the plates from the other open views also get disappeared.
In this way, one can apply Level Display settings to all open views.
