| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX (SS5) & 08.11.11.87 (SS6) | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | OpenPlant Specification Generator | ||
| Subarea: | Auto Branch Table - Half Coupling | ||
| Original Author: | Rahul Kumar, Bentley Product Advantage Group | ||
To output branch lines with reduced half coupling in OpenPlant Modeler.
With the use of Specification generator, user wanted to update branch table with half coupling and wanted to get it picked up by branch table during placement in Modeler. By default only equal size half coupling gets placed. For Reduced size half coupling user need to perform below steps to get branch table for automatic placement.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../13028.openplant-specification-generator
