| Product(s): | ProStructures, ProSteel & ProConcrete |
| Environment: | N/A |
| Area: | Modelling |
| Subarea: | Structural Objects |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
A structure object was inserted twice or accidentally copied to the same position. How can one delete the second structural object with all components?
Here, we will use the example of workframes. In this case, two workframes are created on top of each other and the view frames are exactly coinciding.
It is enough to move one of the two workframes (the object with the numbers on it) . For the moved workframe, all view frames are re-created at the new location.
The extra, moved workframe can then be deleted.
