| Product(s): | ProSteel | ||
| Area: | Workframe & Column Grids | ||
| Subarea: | General - Workframe | ||
This wiki will guide you on how to delete the Workframe in a correct way.
1. Right-click on the Workframe bubble and then select Delete Workframe to delete it.
2. Now, ProStructures dialog pop ups, left-click on the Yes button to delete the Workframe.
In this way, you can delete the Workframe.
