| Product(s): | ProSteel | ||
| Area: | Workframe & Column Grids | ||
| Subarea: | General - Workframe | ||
All created views from workframe were gone, but they are still showing up in detail center, and I can create 2d from that view. But how to bring those views back to the menu so I can select them, without creating the workframe again (picture)?
Enter methods to resolve in this section.
1. Right click on the existing Workframe grid bubble and select the Structural Properties to open the Workframe dialog.
2. Now, randomly change the values in the Layout tab and then set it back to the original values.
3. With this the Workframe get resets and creates the views again in the Select View dialog.
