| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.11.87 | ||
| Environment: | Windows 7/8 (64 bit) | ||
| Area: | Component | ||
| Subarea: | |||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
Earlier when fixing disconnects through connectivity checker, program used to pick first entry from the spec for Bolts and gaskets. In latest release of OpenPlant Modeler SS6, an option has been provided to show spec grid in case of multiple results found while fixing the disconnects.
