| Product(s): | ProSteel | ||
| Area: | Detail Center Standard | ||
| Subarea: | Settings | ||
In this wiki, we will learn how to set the display of single parts only once inside all groups i.e., there should be a new part in each group, and parts with similar position numbers will be displayed only amongst all the groups.
1. Open the Detail Center Standard and click on the parts tab.
2. Under the parts tab, click on the ‘Display and Filter’ button.
3. In the display settings display dialog, check the option ‘New per group’
4. This will set the display of similar single parts to be displayed only once inside the groups i.e. there will be a new part in each and every group.
So, one can use this option to avoid the similar parts amongst all groups and want new parts per group.
