| Product(s): | ProSteel | ||
| Area: | Data/Reporting | ||
| Subarea: | Positioning | ||
In the ProSteel model, there is a possibility that the Groups and Single parts may have the same position numbers due to their similar properties. But, in the Detail Center, all the groups/single parts (especially those having the same position numbers) are not present because of some default settings.
In this wiki, we will learn how to enable the settings so that users can see the multiple entries of parts with similar position numbers in the Detail Center.
1. Make sure that the elements in the model are positioned properly and then navigate to the Detail Center Standard under ProSteel>Drawing Production>Detail Center Standard.
2. Now, In the Detail Center, underparts tab, open the settings for display (refer to the image below)
3. In these settings, under the optional section, uncheck the option ‘Show entries only 1x’
4. This will show all the Groups/Parts (multiple entries of parts with the same position numbers)
In this way, you can enable multiple entries of parts with the same position numbers in the Detail Center.
