| Product(s): | ProSteel | ||
| Area: | Drawing Production | ||
| Subarea: | Drawing Modifications | ||
In this wiki, we are going to learn how to edit/modify the inserted 2D drawing such as a dimension, texts objects lines etc.
1. After inserting the 2D drawing, when trying to edit anything by selecting one of the objects the entire drawing gets selected, as shown in the below image.
2. Enable and again disable the Select Group As Whole PS toggle.
3. Now, we can modify any part in the 2D drawing as per the need.
In this way, we can modify the inserted 2D drawing.
