How to check if the ProjectWise Wrapper files are present or missing in OpenUtilities Substation
 Product(s):OpenUtilities Substation CONNECT Edition
 Version(s): 10.00.XX.XX to 10.14.XX.XX
 Environment: NA
 Area: ProjectWise Integration
 Subarea:NA
Background:
This wiki article will help user determine if the OpenUtilities Substation Wrapper files that are essential for ProjectWise integration are available or missing on the client machine.
1. Using Windows Explorer browse to the location "C:\Program Files (x86)\Bentley\ProjectWise\bin"
2. Then use search to find the files with "Promise" in their inside the folder. check if the below files are present in the folder. If the files are not present, its an indicator that the correct sequence of Installation has not been followed.
 Original Author:Satish Saptasagar
