| Product(s): | ProStructures (ProSteel) | ||
| Area: | 2D Display tab - Detail Style | ||
| Subarea: | Views > Object Display | ||
This wiki explains the different types of display options for 2D Views drawing in Detail Style.
1. Right click on the View from Views tab of Detail Center and select Edit Style to open Detail Style.
2. Go to 2D Display > Views > Object Display and select any display group e.g. Shape.
3. Here, we have following options to use as display of the 2D view drawing for the selected Display Group (e.g. Shape).
NOTE: We can use different or same display options for different Display Groups. In the above image, there only two Display Groups are present, one can even add more required display groups for different kind of object types. For more information, please follow the below wiki link from See Also section.
