Working from home with ProStructures
Resources Bentley:
If you need a new Installation at Home and the download speed is low, users should prepare a  full install via /layout option,
copy the content to an USB Memorystick, and use this full install at home.
Here the link to ProStructures Layout Instruction:
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0106779
When you screen resolution is different a home, because you have another Monitor setup,you need to reset your dialogues
communities.bentley.com/.../reset-dialog-positions
If you would like the setup executable of ProStructures CONNECT Edition (Full) Update 4, please follow these steps to download it from Fulfillment Center or a direct click for ProStructures
  1. Sign in to connect.bentley.com
  2. Choose Software Downloads from "My Support" section.
  3. Select the Brand ProStructures and then select the Generation of CONNECT Edition
  4. Download the latest release by clicking on the arrow to expand the selection and then on ProStructures CONNECT Edition Update 4 version (10.04.00.47)
    Important installation requirements and notices are found in the Readme
For Better Speed of the online help documentation can be used offline.
communities.bentley.com/.../how-to-activate-offline-help
See also our PowerPoint Präsentation with condensed information
communities.bentley.com/.../Working-from-home-with-ProStructures.pptx
Best Regards,
Bentley Technical Support
