The table below lists the supported version of ProStructures if the file is created or saved in the ProStructures CONNECT Edition Update 6 and Update 7.
Since Update 6.xx we are backwards compatible to higher versions. So all Versiona above 6.xx like 7.xx and ProStructures 2023 can be opened in 6.xx.
