| Product(s): | ProSteel | ||
| Area: | ProSteel Tools (Add-On) | ||
| Subarea: | N/A | ||
This section contains all the information about an add-on ProSteel Tools. The ProSteel Tools is a collection of additional tools for ProSteel available for following Versions:
Please follow the below steps to integrate the ProSteel Tools in the latest ProSteel CONNECT Edition.
Please download the required or latest ProSteel Tools ZIP file from the above section and extract them. The zip package does not include an executable file. Hence, these files need be copied manually as motioned below.
1. File included in Gui folder should be copied to following path.
C:\ProgramData\Bentley\ProStructures CONNECT Edition\Configuration\Organization\Dgnlib\Gui
2. Files included in Plugins folder should be copied to
C:\Program Files\Bentley\ProStructures CONNECT Edition\ProStructures\Prg\Plugins
3. Files included in ProStructures folder should be copied to
4. Files included in WorkSpace folder are
and should be copied to your working WorkSpace location
C:\ProgramData\Bentley\ProStructures CONNECT Edition\Configuration\WorkSpaces\<WorkSpaceName>\Standards\ProStructures
Loading the ProSteelTools toolbox:
In ProSteel CONNECT Edition use Ctrl + T to open dialog for Tool Boxes and check the ProSteelTools-Custom and click on the OK button.
