| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | OpenPlant Specification Generator | ||
| Subarea: | - | ||
| Original Author: | Rahul Kumar, Bentley Product Advantage Group | ||
In Specification Generator, some of the components classes required to be shown under branch table.
With the use of Specification generator, Branch Table is being used to pick branch olet, Tees , couplings etc automatically. In Branch Table, user has an option to select these branched components. Branch Table grid carries a drop down list to allow user to picks type of components which suits the requirement. Drop down option does not have a class name to pick, but a branch code that can represent one or more classes. The list if code present inside the drop down list depends on the component of that size present inside the spec. below steps describes the requirement of adding a half coupling inside the Model. .
See Help Menu for additional information.
