| Product(s): | ProSteel | ||
| Area: | Steel Element | ||
| Subarea: | Bolt Styles | ||
This section contains the wikis related to the Bolts tool of ProSteel CONNECT Edition. This tool used to parametrically add individual bolts, nuts, washers, and holes to model bolted connections and can be accessed under the Steel workflow > Home > Steel Placement > Bolts.
Key-in: PROSTEEL PLACE BOLTS
