| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.440/08.11.09.564/08.11.11.87 | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | - | ||
| Subarea: | - | ||
| Original Author: | Rahul Kumar, Bentley Product Advantage Group | ||
To fix ‘Invalid Catalog Selected’ error message in OpenPlant Specification Generator.
In OpenPlant Specification Generator, while creating a catalog using MS Access files, some of the fields or Data Types mismatches with respect to its specs. Further opening the spec using OpenPlant Specification Generator, it throws an error stating Invalid Catalog Selected along with the list of Fields which got problems with the Data Types and its Fields. See below image. Error In table: PIPE Column:THD_ENG_R is defined as System.String instead of System.Double
To fix this problem user need to open the corresponding mdb file using ms access and edit the Data Types and Fields. Below steps will describe the matter significantly.
In OpenPlant Specification Generator, while creating a new catalog for Bolts & further when it gets updated for a spec along with default Bentley catalog, an Error message prompts for "Invalid Catalog Selected"
See Help Menu for additional information.
