| Product(s): | ProSteel | ||
| Area: | Data/Reporting | ||
| Subarea: | External Partlist | ||
This section contains the wikis related to the External Partlist tools of ProSteel CONNECT Edition.
Partlist Creation
Partlist Creation tool used to generate a partlist database (*.mdb) from currently selected steel objects and can be accessed under the Steel workflow > Data/Reporting > Reporting > Create Partlist Database.
Key-in: PROSTRUCTURE CREATE PARTLIST
ProStructures Partlist
ProStructures Partlist used to generate and create the output of a parts list and can be accessed under the Steel workflow > Data/Reporting > Reporting > Create ProSteel Partlist.
Key-in: PROSTRUCTURE LOAD PARTLIST
