sisHYD 2023 License configuration
 Produkt(e):OpenUtilities sisHYD 2023
 Version(en):23.00.00.23
 Umgebung:Windows 10
 Produktbereich:Installation
 Produktunterbereich:Licensing
The OpenUtilities sisHYD 2023 user can specify the sisHYD product variant (sisHYD Heat, sisHYD Gas or sisHYD Multi) and the maximum number of pipes (1000, 10000 or unlimited).
The configuration is done by setting the environment variable SISHYD_FEATURE before starting the application.
The variable SISHYD_FEATURE must be set in the desktop shortcut directly after installation, with your correct licence data!
In the following example, a gas licence is configured to handle up to 1000 lines:
"C:\Programme\Bentley\OpenUtilities sisHYD 2023\OpenUtilitiesSisHYD\OpenUtilitiesSisHYD.exe"
-wsSISHYD_FEATURE=medium=gas|pipe=1000
"C:\Programme\Bentley\OpenUtilities sisHYD 2023\OpenUtilitiesSisHYD\OpenUtilitiesSisHYD.exe" -wsSISHYD_FEATURE=medium=gas|pipe=1000
Variants
VariableValueMeaning
SISHYD_FEATUREmedium=gas|pipe=1000sisHYD Gas max. 1000 pipes
SISHYD_FEATUREmedium=gas|pipe=10000sisHYD Gas max. 10000 pipes
SISHYD_FEATUREmedium=gas|pipe=unlimitedsisHYD Gas unlimites pipes
SISHYD_FEATUREmedium=heat|pipe=1000sisHYD Wärme max. 1000 pipes
SISHYD_FEATUREmedium=heat|pipe=10000sisHYD Wärme max. 10000 pipes
SISHYD_FEATUREmedium=heat|pipe=unlimitedsisHYD Wärme unlimites pipes
SISHYD_FEATUREmedium=multi|pipe=1000sisHYD Multi max. 1000 pipes
SISHYD_FEATUREmedium=multi|pipe=10000sisHYD Multi max. 10000 pipes
SISHYD_FEATUREmedium=multi|pipe=unlimitedsisHYD Multi unlimites pipes
