| | Product(s): | ProSteel | |
| | Version(s): | CONNECT Edition (10.XX.00.XX) | |
| | Area: | Steel Elements | |
| | Subarea: | Workframe & Column Grids | |
| | Original Author: | Vyanktesh Nama, Bentley Product Advantage Group | |
This section contains the wikis related to the
Workframe and
Column Grids tools of ProSteel CONNECT Edition. These tools can be accessed under the Steel workflow > Home > Elements > Workframe & Column Grids.
Workframe:
All ProStructures models are started with the creation of one or several Workframes. A Workframe represents the basic spatial dimensions of your project in a 3D view.
Column Grids:
This tool is used to set the shape, size, placement, and appearance of all elements and components contained in a grid system.
See Index
This video is the first part of the ‘Workframe’ tutorial series. The video provides a basic overview of the Workframe tool, guide you through its functionalities, and demonstrate how to use it for structural design. | youtu.be/l1kMqwW06L4 |
This video is the second part of the 'Workframe' tutorial series. It explains how gridlines of a workframe can be edited after its placement and other interesting features related to axes descriptions as assignment of manual descriptions, different styles of axes description etc. | youtu.be/XCY56y9QjIk |
This is the third part of the 'Workframe' tutorial series. This video gives an overview of how the Workframe tool can be used to create combined Workframes. You will also learn how to create combined Workframes for an unsymmetrical structure. | youtu.be/Fjf5bkKjecM |
This is the fourth part of 'Workframe' tutorial series. This video will demonstrate you the method of inserting a workframe in an existing model. | youtu.be/l0P9s-lE6VU |
