Changing ProductIDs between V8i and CONNECT Edition
Users of sisNET, sisFLOW or sisVIEW capabilities on V8i SS4 were using these capabilities as part of the OpenUtilities Designer, Map or PowerView products. Since the first release of sisNET CONNECT Edition (CE), we are switching from OpenUtilities Designer, Map and PowerView products to sisNET, sisFLOW and sisVIEW products. Users of sisIMS V8i also had Geo Web Publisher (GWP), Geo Web Solutions (GWS) and MicroStation for the sisIMS servers in their contract.
After upgrading to CE, many of these products are no longer needed. They are removed from the SELECT contract at the first renewal after a user has upgraded to CE. The impact on the contract price is minimal, if any, because desktop users did not have to pay separately for the OpenUtilities Designer, Map or PowerView licenses, and because the SELECT costs of the sisIMS-related products GWP, GWS and MicroStation are now included in the SELECT cost of sisIMS CE.
Bentley products are listed on SELECT contracts with a Material number and a Material Description. See the following table for an overview of the products that are no longer needed:
Product Name |
ProductID |
Material |
Material Description |
OpenUtilities Designer |
2164 |
9422 |
Bentley OpenUtilities Designer SELECT Su |
OpenUtilities Map |
2418 |
11247 |
Bentley OpenUtilities Map SELECT Sub |
OpenUtilities PowerView |
2419 |
11243 |
Bentley OpenUtilities PowerView SELECT S |
Geo Web Publisher |
1189 |
11811, 11812, 11813 (for 10, 50, 100 users) |
Geo Web Publisher (10, 50, 100) User SELECT Sub |
Geo Web Solutions |
1213 |
11908 (10 users) |
Geo Web Solutions 10 Users SELECT Sub |
MicroStation |
1000 |
1003 |
MicroStation SELECT Subscription |
Changing sisNET ProductIDs since CE Update 5
Since sisNET CE Update 5, we are transitioning to a new, single ProductID for all sisNET products. To replace the old sisNET Electric, Heat, Gas, Water, Wastewater and Multi Utility products and their ID's to the one new ProductID 3172, the following procedure is used:
For sisIMS, sisFLOW and sisVIEW, there are no changes in ProductIDs or Material numbers.
The following table lists the old sisNET ProductIDs and their SELECT Materials:
Product Name |
Old ProductID |
Old Material |
Old Material Description |
OpenUtilities sisNET Electric |
1656 |
4343 |
D* Bentley OU sisNET Electric SELECT Sub |
OpenUtilities sisNET Heat |
1657 |
4351 |
D* Bentley OU sisNET Heat SELECT Sub |
OpenUtilities sisNET Gas |
1658 |
4356 |
D* Bentley OU sisNET Gas SELECT Sub |
OpenUtilities sisNET Water |
1659 |
4362 |
D* Bentley OU sisNET Water SELECT Sub |
OpenUtilities sisNET Wastewater |
1660 |
4367 |
D* Bentley OU sisNET Waste Water SELECT |
OpenUtilities sisNET Multi Utility |
1661 |
4346 |
D* Bentley OU sisNET M' Utility SELECT S |
The next table lists the new sisNET ProductID and its new SELECT Materials:
Product Name |
ProductID |
Material |
OpenUtilities sisNET |
3172 |
15308 |
OpenUtilities sisNET Energy SELECT Sub |
15311 |
OpenUtilities sisNET Water SELECT Sub | ||
15314 |
OpenUtilities sisNET Multi SELECT Sub |
As an example, if you had the following mix of old sisNET products in your contract:
then you will keep all these old licenses free of charge for 1 year, and get the following paid licenses added to your contract:
