| Product(s): | OpenPlant Modeler | ||
| Version(s): |
08.11.11.87 (SS6)/08.11.09.xxx (SS5) | ||
| Environment: | Windows 7 (64-bit) | ||
| Area: | OpenPlant Specification generator | ||
| Subarea: | Data | ||
| Original Author: | Deepak Singh, Bentley Product advantage Group | ||
In OpenPlant Specification Generator, creating OpenPlant Spec using AutoPlant Catalogs.
With the use of Specification Generator, user can create spec for OpenPlant Modeler from AutoPlant Catalogs.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../29122.how-to-add-a-lookup-value-for-a-particular-constraint
