| ADO ID | Title |
| 1173522 | [PW Integration] It cannot load catalog details correctly with PW |
| 1203613 | [Security][Severity-High] - openssl-OpenSSL_1_1_1s (CVE-2012-2677). |
| 1203625 | [Security][Severity-Medium]- boost-boost_1_69_0-bin-msvc-all-32-64(CVE-2012-2677) |
| 1203629 | [Security][Severity-High]-log4cxx-apache-log4cxx-0.12.1(CVE-2023-31038) |
| 1203634 | [Policy Violations] [AppSec]- log4cxx-apache-log4cxx-0.12.1 |
| 1212031 | [Release Audit] Fix digital signature failures in release audit. |
| 1241697 | [Import BOM Data] user data from bmdata table / Json BomItems missing after import |
| 1300880 | [Auto Backup] The SubstationBackupStarter.exe (PromiseBackupStarter.exe) can’t work. |
| 1300596 | Wire number attribute not working |
| 1300873 | [Ribbon] [PLC Generator] It can’t open PLC Generator after clicking the ribbon of it. |
| 1298492 | [PW][CPU] The process ‘RemoteService for Windows’ always occupy high CPU usage even we stop to use Promis.e |
| 1183435 | [Update page]Using user’s project, copy the pages to destination project, update pages, the user cannot insert balloon for the object in the construction drawing. |
| 1283350 | [Dimension Styles] user defined styles from dgnlib seed missing from active dgn |
| 1281698 | [Promis.e 2023][PW Explorer] an error occurs renaming page from PW Explorer |
| 1278496 | [Txt Mode][Create Symbol]It always popup unexpected dialog when inserting an modified symbol. |
| 877197 | [Copy Page] Page Copy does not copy Drawingset &Installation &Location Descriptions |
| 1280011 | [Modify Page]Change the title block in the Modify page dialog, the title block cannot be changed. |
| 1278304 | [Copy Page] It reports error to copy page of a new created project. |
| 1273549 | [Txt Mode][Create Symbol]The symbol is not a real symbol if modify the symbol text attribute in the Attribute Edit dialog and overwrite the original symbol.. |
| 1276770 | [PLC Generator] Sometimes running PLC Generator command reports error with Substation build in Win 10 system |
| 1261195 | [Symbol Creation][Text Settings] incorrect information dialog displayed followed by Unhandled Exception error |
| 1269714 | [Create Symbol][Catalog.txt]When modifing the symbol the Catalog not saved in the default catalog where it was selectd from |
| 1269857 | [Symbol Creation][Replace Symbol] Replace symbol does not work correctly after modifying already placed symbol |
| 1261210 | [Change Text Attributes] internal error messages and data corruption after using Change Text Attributes for text assocaited to Substation objects like symbols & wires |
| 1267851 | [Balloon No] After modify balloon placed by symbol, it cannot update related balloon placed by device on construction drawing |
| 1269433 | [Page Management] Switch projects that have different DBs, Compare DS/IN/LO descriptions and Apply Page Property Data report error |
| 1269444 | [Automatic Wire Number]Auto wirenumber for the whole demo project, it popups error dialog. |
| 1261182 | [Symbol Creation][Attribute Editor] Internal Error Message apears after adding Expression |
| 1257955 | [Txt Environment] It always prompts Multi_Language_UI path incorrect in Configuration Variables dialog |
| 1254670 | [Cable Diagrams] Parts Database attributes on cable diagram symbol not populated after user clicks Update Wire Diagram |
| 1103492 | [Copy Page]Modify the page description in Data Manager in Source project, and copy the page from source to destination project, the modified info cannot display correctly in the Modify Page dialog. |
| 1258825 | [Txt & Mdb Compatibility ] Switching project from Txt to mdb or mdb to Txt environment reports error |
| 1259302 | [Switch Workspace]It should give a message to tell user when switch workspace from one txt to mdb or mdb to txt environment |
| 1260724 | [Update Wiring Diagram]Restore an old project which the project name has uppercase and lowercase letters, update wiring diagram mode page, it cannot output the cable diagram info. |
| 1256970 | [PW]Connect with PW, open a page, and then close the page, it always popup unexpected dialog. |
| 1153027 | [New Project] Run Rebuild Project Database for sample project reports last error after created several new projects |
| 1112838 | [Copy Page][Cable Text]Copy page from source project to destination project, the cable infor cannot list in the Cable List Report in destination project. |
| 904393 | [Insert Symbol by Device ID]There are unexpected record in the insert symbol by device id dialog if there are more than three parent symbol and all their child symbols are placed. |
| 1015877 | [Wire Manager] Incorrect wire use names can be entered in the Wire Manager |
| 1254678 | [Import Catalog] multiple error messages appear when importing ctlg into existing catalog |
| 1244371 | [Insert Balloon][BOM Manager]Renumbering the balloons causes the Balloon Callouts to move |
| 876570 | [Project Manager][Restore Project] Restore project name should support lower case and upper case |
| 881520 | [Insert Symbol][Insert Macro] User gets alert message when using Insert Symbol/Insert Macro tool "Can not write to current page" |
| 1017429 | [Net WorkSpace][Multi-User]UserA insert a macro with terminal, it popups error dialog when UserB insert the same macro. |
| 1098733 | [Update Page][Navigate]Copy a page from source project to destination project, right click a symbol crossreference->click Navigate, try to navigate to an page which is not existed, the software crash. |
| 1099521 | [Copy Page][Update Page]The cross reference info still display in the drawing in the copied page if the Drawing Naming=[Page Number] in both the Source project and Destination project. |
| 1103533 | [Copy Page]Sometimes the project name in the copied page drawing is not correct, it still use the Source project name. |
| 1109639 | [Copy Page]Copy page with Cables from source to destination project, the cable only in the single line mode cannot list in the Cable Manager dialog in Destination project. |
| 1110926 | [Copy Page][Cable Text]Delete cable text in Cable Manager dialog from source project and copy to the destination project, the deleted records are not correct. |
| 1195258 | [Wiring Manager][Update Page]Add label for a wire without wire number, and then update page, the wire will has an unexpected wire number. |
| 1178600 | [Apply Page Property Data][PW]If selection set contains one or more pages either checked out by different user or open by different user, “Apply Page Property Data” on right click menu must be un-selectable. |
| 1212920 | [Copy] It reports error to copy a circuit with field. |
| 1106801 | [Favorites] The page list is missing from Favorites after rename project via Favorites |
| 1220774 | [Page Format][Cross Reference Text]Some wire links have wrong cross reference value |
| 418196 | [PW Integration] Cannot update project properties immediately in PW Explorer after modifying project properties from Substation |
| 1215539 | [Insert Symbol by Name]It cannot assign the part number from the selected device tag correctly when user insert a symbol in the Device Properties dialog firstly. |
| 1215215 | [ProjectWise Integration][ProjectOptions.xml] When a user has ProjectOptions.xml checked-out when another user tries to work on the projects they get "No Active Project" message |
| 1196809 | [PW integration] It should allow pw user who has read permission access to ProjectOption.xml to create new page on PW client side |
| 1111497 | [PW Integration]Modify page descriptions values in PW Explorer, the values cannot be updated in the Substation client. |
| 1028636 | [Remove catalog.mdb][Workspace]Switch workspace from txt environment to mdb environment, Multi_Language_UI cannot switch correctly in Configuration Variables dialog |
| 477184 | [PW integration][PG&E Environment]Configuration Variables dialog gets crash during validation |
| 680349 | [Right click menu][Smart Move] Right click menu command Smart Move will be invalid with the duplicated ID symbol |
| 1015899 | [Remove Catalog.mdb]Txt env->create a project with Regional setting->set a new created language, and then convert back to mdb model, and It popups error dialog when trying to insert a symbol with symbol text in the same project. |
| 1081141 | [Balloon Callout] Users can modify the balloon number in the balloon callout text |
| 938602 | [Balloon]Reference the file in a page with Title Block in sheet model, the modified balloon value cannot update in the reference file. |
| 945667 | [PW][Delete Page]Open a page in ProjectA, and then delete a page in ProjectB, the page cannot be deleted connect with PW. |
| 1094256 | [Restore Project] Move to Database command changes the default project in the restore project dialog |
