| Product(s): | ProSteel | ||
| Area: | Detail Center Standard | ||
| Subarea: | Detail Center | ||
This section contains the wikis related to the Detail Center Standard tool of ProSteel CONNECT Edition. This tool is used to transform your model into 2D drawings and can be accessed under the Steel workflow > Drawing Production > Detailing > Detail Center Standard.
