Compatibility Chart - Promis.e CONNECT Update 11 to 13, 2023 to 2024
  Product(s): Promis.e CONNECT
  Version(s): 10.11.XX.XX to 24.00.00.XX
  Environment: N/A
  Area: Installation_Configuration
  Subarea: Compatibility Chart - Promis.e CONNECT Edition
The purpose of this document is to indicate the compatibility of various software with Promis.e. It is not intended to describe the compatibility of the various software with each other.  For example, certain versions of SQL Server may not be compatible with certain operating systems. Always check the documentation of the various software involved.
An archive of the compatibility chart for Promis.e 2007 through Promis.e V8i SS3 can be found [[5648|here]].
For Promis.e V8i version Compatibility Chart click here.
  Promis.e Version CONNECT Update 11 (10.11.00.58) CONNECT Update 12 (10.12.00.49) CONNECT Update 13 (10.13.00.48) CONNECT 2023 CONNECT 2023 U1 CONNECT 2024
  Operating System
  Windows 11 (64-bit) Yes Yes Yes Yes Yes Yes
  Windows 10 (64-bit) Yes Yes Yes Yes Yes Yes
  Windows 8.1 (64-bit) Yes Yes No No No No
  Windows 7 (64-bit) No   No No No No
  Windows Server 2019 (64-bit) Yes Yes Yes Yes Yes Yes
  Windows Server 2016 (64-bit) Yes Yes Yes Yes Yes Yes
  Windows Server 2012 (64-bit) Yes   No No No No
  Database Software
  SQL Server 2022 (Inclusing Express) No No No Yes Yes Yes
  SQL Server 2019 (Inclusing Express) Yes* Yes* Yes* Yes Yes Yes
  SQL Server 2017 (Inclusing Express) Yes* Yes* Yes* Yes Yes Yes
  SQL Server 2016 (Including Express) Yes* Yes* Yes* Yes Yes Yes
  ProjectWise Integration
  ProjectWise 2024 20.00.00.5502         Yes Yes
  ProjectWise 2023 23.06.03.12         Yes Yes
  ProjectWise 2023 23.06.00.30 No No No No Yes Yes
  ProjectWise 2023 23.06.00.15 No No No No Yes Yes
  ProjectWise 2023 23.06.00.11 No No No No Yes Yes
  ProjectWise CONNECT 10.00.03.453 Yes Yes Yes Yes Yes Yes
  ProjectWise CONNECT 10.00.03.434 Yes Yes Yes Yes Yes Yes
  ProjectWise CONNECT 10.00.03.334
  ProjectWise CONNECT 10.00.03.329
  ProjectWise CONNECT 10.00.03.299 Yes Yes Yes Yes
  ProjectWise CONNECT 10.00.03.280
  ProjectWise CONNECT 10.00.03.271
  ProjectWise CONNECT 10.00.03.262
  ProjectWise CONNECT 10.00.03.167
  ProjectWise CONNECT 10.00.03.140
  ProjectWise CONNECT 10.00.02.320 No No No No No No
  ProjectWise CONNECT 10.00.02.265 No No No No No No
  Microsoft Office 365 Version
  Microsoft 365 Version 2408         Yes Yes
  Microsoft 365 Version 2407         Yes  Yes
  Microsoft 365 Version 2403         Yes
  Microsoft 365 Version 2402         Yes Yes
  Microsoft 365 Version 2401         Yes
  Microsoft 365 Version 2309       Yes
  Microsoft 365 Version 2308       Yes Yes Yes
  Microsoft 365 Version 2307       Yes
  Microsoft 365 Version 2303 No Yes Yes Yes
  Microsoft 365 Version 2302 No Yes Yes Yes Yes
  Microsoft 365 Version 2211 No Yes
  Microsoft 365 Version 2210 No Yes
  Microsoft 365 Version 2209 No Yes
Refer the Promis.e CONNECT Readme for details. For Online Promis.e Readme click here.
Important Notes
communities.bentley.com/.../promis-e-connect-edition-system-requirements
[[Project Database Version]]
[[Updating and Upgrading promis.e]]
[[How to download the promis.e software]]
[[Moving From promis.e for AutoCAD to promis.e Standalone]]
[[Compatibility Chart - Bentley Substation]]
