| Product(s): | OpenUtilities Substation | ||
| Version(s): | 10.13.00.XX to 24.00.00.XX | ||
| Area: | Installation_Configuration | ||
| Subarea: | Compatibality Chart OpenUtilities Substation |
The purpose of this document is to indicate the compatibility of various software with OpenUtilities Substation CONNECT. It is not intended to describe the compatibility of the various software with each other. For example, certain versions of SQL Server may not be compatible with certain operating systems. Always check the documentation of the various software involved.
| OpenUtilities Substation CONNECT Edition | Update 13 (10.13.00.84) | Update 14 (10.14.00.92) | Update 15 (10.15.00.57) | 2023 | 2023 U1 | 2024 |
| Operating System | ||||||
| Windows 11 (64-bit) | Yes | Yes | Yes | Yes | Yes | Yes |
| Windows 10 (64-bit) | Yes | Yes | Yes | Yes | Yes | Yes |
| Windows 8.1 (64-bit) | Yes | No | No | No | No | |
| Windows 7 (64-bit) | No | No | No | No | No | No |
| Windows Server 2019 (64-bit) | Yes | Yes | Yes | Yes | Yes | Yes |
| Windows Server 2016 (64-bit) | Yes | Yes | Yes | Yes | Yes | Yes |
| Windows Server 2012 (64-bit) | Yes | No | No | No | No | |
| Database Software | Update 13 (10.13.00.84) | Update 14 (10.14.00.92) | Update 15 (10.15.00.57) | 2023 | 2023 U1 | 2024 |
| SQL Server 2022 (Inclusing Express) | No | No | No | Yes | Yes | Yes |
| SQL Server 2019 (Inclusing Express) | Yes* | Yes* | Yes* | Yes | Yes | Yes |
| SQL Server 2017 (Inclusing Express) | Yes* | Yes* | Yes* | Yes | Yes | Yes |
| SQL Server 2016 (Including Express) | Yes* | Yes* | Yes* | Yes | Yes | Yes |
| ProjectWise Integration | Update 13 (10.13.00.84) | Update 14 (10.14.00.92) | Update 15 (10.15.00.57) | 2023 | 2023 U1 | 2024 |
| ProjectWise 2024 24.00.00.5502 | Yes | Yes | ||||
| ProjectWise 2023 23.06.03.12 | Yes | Yes | ||||
| ProjectWise 2023 23.06.00.30 | No | No | No | No | Yes | Yes |
| ProjectWise 2023 23.06.00.15 | No | No | No | No | Yes | Yes |
| ProjectWise 2023 23.06.00.11 | No | No | No | No | Yes | Yes |
| ProjectWise CONNECT 10.00.03.453 | Yes | Yes | Yes | Yes | Yes | Yes |
| ProjectWise CONNECT 10.00.03.434 | Yes | Yes | Yes | Yes | Yes | Yes |
| ProjectWise CONNECT 10.00.03.334 | ||||||
| ProjectWise CONNECT 10.00.03.329 | ||||||
| ProjectWise CONNECT 10.00.03.299 | Yes | Yes | Yes | Yes | Yes | Yes |
| ProjectWise CONNECT 10.00.03.280 | ||||||
| ProjectWise CONNECT 10.00.03.271 | ||||||
| ProjectWise CONNECT 10.00.03.262 | ||||||
| ProjectWise CONNECT 10.00.03.167 | ||||||
| ProjectWise CONNECT 10.00.03.140 | No | No | No | No | No | No |
| ProjectWise CONNECT 10.00.02.320 | No | No | No | No | No | No |
| ProjectWise CONNECT 10.00.02.265 | No | No | No | No | No | No |
| Microsoft Office 365 Version | Update 13 (10.13.00.84) | Update 14 (10.14.00.92) | Update 15 (10.15.00.57) | 2023 | 2023 U1 | 2024 |
| Microsoft 365 Version 2408 | Yes | Yes | ||||
| Microsoft 365 Version 2407 | Yes | Yes | ||||
| Microsoft 365 Version 2403 | Yes | Yes | ||||
| Microsoft 365 Version 2402 | Yes | Yes | ||||
| Microsoft 365 Version 2401 | Yes | Yes | ||||
| Microsoft 365 Version 2309 | Yes | |||||
| Microsoft 365 Version 2308 | Yes | Yes | Yes | |||
| Microsoft 365 Version 2307 | Yes | |||||
| Microsoft 365 Version 2303 | No | Yes | Yes | Yes | ||
| Microsoft 365 Version 2302 | No | Yes | Yes | Yes | Yes | |
| Microsoft 365 Version 2211 | No | Yes | ||||
| Microsoft 365 Version 2210 | No | Yes | ||||
| Microsoft 365 Version 2209 | No | Yes | ||||
1* Limited support. Tested with Windows 7 SP1. In Windows 7 SP1, Backup Project, Copy Project (to another database) and Move To Database functions do not work. This is resolved in CONNECT Edition Update 1.
2* Requires Windows 7 SP1 Operating System.
