| Product(s): | ProSteel | ||
| Area: | Data/Reporting | ||
| Subarea: | Positionflags & Positioning | ||
This section contains the wikis related to the Positionflags & Positioning tool of ProSteel CONNECT Edition. This tool used to create or automatically generate position numbers and flags for parts in a 3D model for final detailing and can be accessed under the Steel workflow > Data/Reporting | Drawing Production > Numbering > Positioning.
Key-in: PROSTRUCTURE POSITION
