| Product(s): | ProSteel | ||
| Area: | Steel Elements | ||
| Subarea: | Shapes | ||
This section contains the wikis related to the Shapes tool of ProSteel CONNECT Edition. This tool used to place straight, bent, or spiral shapes from catalog sections into your ProStructures/ProSteel model and can be accessed under the Steel workflow > Home > Steel Placement > Shapes.
Key-in: PROSTEEL PLACE SHAPE
