How to Swap Coordinates Annotation in OpenPlant Isometrics Manager-v8i
 Product(s): OpenPlant Isometrics Manager
 Version(s): 08.11.11.87 (SS6) & 08.11.11.98 (SS6) above
 Environment: Windows 7 (64bit) & Others
 Area: Settings/Attributes
 Subarea: Coordinates - Swapping-Annotation
 Original Author: Rahul Kumar, Bentley Product Advantage Group
In OpenPlant Isometrics Manager, to manage coordinate annotation swapping.
In OpenPlant Isometrics Manager, there is an option to swap coordinates annotation. Below steps describes on how to manage swapping for coordinates. It has been written in context with OpenPlant Modeler and OpenPlant Isometrics Manager. However similar method can be used for AutoPLANT Modeler and OpenPlant Isometrics Manager.
  1. Navigate to project folder for style.cfg file. Below default path for reference.
    (...\WorkSpace\Projects\OPModeler_Metric\DataSet\Isometrics\Styles\IFC\Config)
  2. Open style.cfg file.
  3. Search for default variable IE_COORD_SWAP. See image below.
    Note –
    By default, it is given as 0.
  4. See image below on default.
  5. Add IE_COORD_SWAP = 1 as shown in below image.
  6. Save & Close file.
  7. See result below after modification.
communities.bentley.com/.../12638.modifying-text-and-annotation-settings
Comments or Corrections?
