| Product(s): | ProSteel | ||
| Area: | Steel Element | ||
| Subarea: | Plates/Polyplates | ||
This section contains the wikis related to the Plates/Polyplates tool of ProSteel CONNECT Edition. This tool used to create and place straight, arc, and web grating from catalog sections into your ProStructures/ProSteel model and can be accessed under the Steel workflow > Home > Steel Placement > Plates.
Key-in: PROSTEEL PLACE PLATE
