The table below lists the fixes and enhancements in sisNET CONNECT Edition Update 5, with version number 10.16.05.09, released on February 11, 2022. Update 5 was built on PowerPlatform 10.16.02 and OpenCities Map 10.16.02.
The table is sorted on ID; note that some ID fields contain multiple or blank values.
| ID | New | Change | Bug | Description |
| 097602 | X | sisNET Tools: DB update now also recreates the _GEOM_VIEW and _TEXT_VIEW views. | ||
| 098064 | X | sisNET: If an object type is deleted in the configuration, the entries for this object type are now also deleted from the Oracle Spatial configuration during database synchronization. | ||
| 098404 | X | sisNET: For dimension lines in the as-built plan, it is now possible to delete individual object parts again. | ||
| 206046 | X | sisNET: When saving labels in OpenGIS, the label ID and the DAS type are now also stored in the _GEOM_BEST table. | ||
| 207408 | X | sisNET: relations of cadastre feature types to types from other commodities can now also be exported. This option can be found under „Options“ in the export dialog and is deactivated by default. | ||
| 211540 | X | sisNET: If a feature is defined not to be saved in pool files (line 34), this feature type is also no longer listed in the configuration of the Oracle Spatial storage. When saving a job, geometries of this object type are no longer considered in Oracle Spatial storage. | ||
| 224113 | X | sisNET: OpenGIS storage: deactivation left some data | ||
| 491591 | X | sisNET,sisFLOW: if some ribbongroups are empty because of missing rights they won’t be shown anymore. | ||
| 501438 | X | sisNET: Tab „Administration“ in the sisNET ribbon can be deactivated by using the environment variable „SISNET_ DISABLEADMINMENU“. | ||
| 548126 | X | sisNET: The sript to create an Oracle Pluggable Database was enhanced tob e able to specify the tablespace size. | ||
| 579814 | X | sisNET: The error when saving a DGN file as DXF by using the „Save as“ dialog out of the backstage has been fixed. | ||
| 579814 | sisNET: The error when saving a DGN file as DXF by using the „Save as“ dialog out of the backstage has been fixed. | |||
| 618523 | X | sisNET: changing the filter library multiple times crashed sisNET sometimes. This has been corrected. | ||
| 645553 | X | sisNET: userdefined toolboxes using named expressions provided by sisNET may get wrong evaluation results because of timing problems at startup. This can be fixed by using the environment variable SISNET_SYNC_TOOLBOXES = 1. | ||
| 670052 | X | FMEPlugin: sisNET Aimp Plugin for FME 2021 64 Bit has been released. | ||
| 675104 | X | sisNET Tools: Add Maps gave an error when adding raster maps. This has been fixed. | ||
| 676665 | X | sisNET: „move annotation“ can now be used again for DIMENSION features | ||
| 678295 | X | sisNET: the context menu now shows the “show SAP Object” and “release SAP link” entries. | ||
| 679792 | X | sisNET: HR module – crash while adding a pipe tot he list of blocked pipes has been fixed. | ||
| 679891 | X | sisNET: the error using Undo button contained in the shortcut menu has been fixed. | ||
| 681709 | X | sisNET: creating a fence using macro FENCEAREA has been fixed. | ||
| 683563 | X | sisNET: using macro LEVELSYMBOLOGY_OFF now shows the results directly. Refreshing the view is now longer needed. | ||
| 683776 | X | sisNET: Module CROBJ has been corrected. | ||
| 690123 | X | sisNET: georeferenced raster files will now be attached correctly. | ||
| 690194 | X | sisNET: the problem showing a selection with fitted view has been fixed. | ||
| 701535 | X | sisNET: It’s now possible to move the Objecteditor window outside the sisNET main window. | ||
| 714066 | X | sisNET: Batchplot crashes has been fixed. | ||
| 714711 | sisNET: the licensing has been enhanced. Using the environment variable SISNET_LICENSE_USE_FEATURESTRINGS=1 allows the use of the new 3172 license. | |||
| 719466 | X | sisNET: using geometries out of DWG references is now possible with option „import grafic“ and using the module UMLIN. | ||
| 721279 | X | sisNET: module SROHR creates the protection tube only for the wire or pipe that gets the relation. | ||
| 729759 | X | sisNET: during the installation sis_data can also be specificated by UNC path. | ||
| 736308 | X | sisNET: starting sisNET by doubleclicking a DGN file uses a ‚sisNET Multy Utility‘ or a ‚sisNET Multi‘ license. To force sisNET to use the new ProductID (sisNET Multi, 3172) the environment variable SISNET_LICENSE_USE_FEATURESTRINGS=1 should be used at system level: Control panel --> System Properties -> Environment Variables and then at user level. | ||
| 737085 | X | sisNET: the wrong position of the geometry placed by module UMSTATION2 has been fixed. | ||
| 739656 | X | sisIMS Application server, Engine: with the new environment variable WEBSRV_ENGINE_REFRESHPOLICY an optimization of the sisIMS engine performance can be achieved. The update strategy consists of initializing the engine cache at regular intervals and restarting the engine after a certain number of generated sections. In conjunction with the new tool, EngineMonitor, monitoring of a particular engine can be designed so that when the engine has been shut down in a controlled manner by the refresh strategy, the EngineMonitor tool restarts it. Update strategy examples: WEBSRV_ENGINE_REFRESHPOLICY 1. ""5;10"": => after every 5 requests an init cache is triggered, after 10 init caches (50 requests) the engine is shut down 2. ""10;0"": => after every 10 requests an init cache is triggered, no shutdown 3. ""0;100"": => no init cache is triggered, shutdown after 100 requests. | ||
| 741967 | X | sisNET HTML documentation: The erroneous 'FileTypen' HTML page has been corrected. | ||
| 744273 | X | sisNET Tools: new featuretypes now are getting a correct RNG view after the first DB update. | ||
| 758587 | X | sisNET: the crash when using the TopoLayer_CreateFromSelection macro function has been fixed. | ||
| 759862 | X | sisNET Tools: DB update sometimes started the Theme configurator at the end. This has been fixed. | ||
| 780248 | X | sisNET: the crash when displaying a selection in the selection tool was fixed. | ||
| 783539 | X | sisNET: The crash when using the view brightness slider has been fixed. The platform 10.16.5.7 or higher is required for the bug fix. | ||
| 784177 | X | sisNET: The GEFLIB DUMPLEVELTABLE command now works again. | ||
| 789907 | X | sisVIEW: The "Detach References" button in the sisVIEW ribbon now also detaches all raster references. | ||
| 789908 | X | sisVIEW: The delete button in the sisVIEW Ribbon under Redlining works again. | ||
| 792544 | X | sisIMS Desktop, Mobile: Support for external WMS services of version 1.3 implemented | ||
| 796570 | X | sisNET: The protection tube SROHR module can now be created over several lines to which a relationship is also established. | ||
| 799886 | X | sisNET: The problems in the interactive mode of the batch plot tool have been fixed. | ||
| 492323, 645239 | X | sisNET Tools: the project lock during DB update was released to early. This has been corrected. | ||
| 674971 | X | sisNET: macro EXPLORER_GETCURRENTTHEME(viewNr) allows a better control oft he workflow in batches: # Explorer control # get current Theme m: _theme = EXPLORER_GETCURRENTTHEME(-1) ASK('&_theme') # activate new theme k: laden explorerthema Wasser m: ASK(EXPLORER_GETCURRENTTHEME(-1)) # deactivate Explorer EXPLORERTOGGLE(0) ASK(EXPLORER_GETCURRENTTHEME(-1)) # activate Explorer EXPLORERTOGGLE(1) ASK(EXPLORER_GETCURRENTTHEME(-1)) # activate first theme k: laden explorerthema &_theme m: ASK(EXPLORER_GETCURRENTTHEME(-1)) | ||
| 676666, 676667 | X | sisNET: real values will be displayed correctly creating or modifying a DIMENSION feature. | ||
| 701061, 738808 | X | X | sisNET: the list of tollboxes has been changed. All toolboxes can be activated using the Task dialog or using the list of toolboxes. Some names have been changed. | |
| 767291, 767290, 707764 | X | sisIMS Desktop, Engine: The occasional changes of colors in the current color table led to incorrect display of some objects in browsers. The bug is fixed now. sisNET: Color table to DGN - fixed with new PowerPlatform | ||
| 785105, 794850 | X | sisNET: The electricity calculation network model (SRM) is now working again. |
