| Product(s): | ProSteel | ||
| Area: | Detail Style | ||
| Subarea: | Default Settings tab | ||
This wiki shows different drawing alignment options in Detail Style.
Enter methods to resolve in this section.
1. Open assigned Detail Style.
2. Go to Default Settings > Common and here you can find different options in the Alignment dropdown.
3. Set the required alignment option and update the preview to confirm.
