| Product(s): | ProSteel |
| Area: | Detail Style |
| Subarea: | Default Settings tab |
| Original Author | Steffen Knoll, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
The creation of 2D drawings for single parts allows an automatic selection of partial views (front, back, left...). The automatic selection shows the views that have modifications.
1. Sample here is a rectangular pipe with different holes from front and back.
2. Open Detail Center and go to Detail Style > Default Settings > Partial Views and activate Automatic Selection.
Another option is to set one view as standard view, which will be detailed every time, for example the front view.
3. The display of holes should be Hidden only Axis and no Real Holes.
4. The result shows front and back view with the dimensions of the different holes.
