| Product(s): | ProSteel | ||
| Area: | Detail Center & Drawing Production | ||
| Subarea: | Default Settings - Detail Style | ||
This wiki shows how to get the isometric view of the group (or assembly) with position flags in the 2D group (or assembly) drawing.
1. Open Detail Center, load or create detail styles for Group and Isometric view. Then open the isometric detail style and under the Common page make sure that the Position Flags and Description options are turned on.
2. Go to Descriptions > Position Flags and turn off the option Only first part view to get the position flags in the group drawing for isometric view. Also, select the required alignment and the position flag template.
3. Now, assign group model to group detail style and preview & open detail style.
4. Go to Default Settings > Partial Views and turn on the Isometric View 1, then select the isometric detail style and its position as shown in the below image.
5. After updating the preview, you can see the isometric view of a group in the same group drawing with the position flags as shown in the below image.
In this way, we can get the isometric view of the group (or assembly) with position flags in the 2D group (or assembly) drawing.
