| Product(s): | AutoPLANT P&ID | ||
| Version(s): | V8i | ||
| Area: | VBA Dialogs | ||
| Subarea: | Download Object Enablers | ||
| Original Author: | Brandon Moberg, Bentley Product Advantage Group | ||
To run AutoPLANT P&ID V8i (SELECTseries 5) with AutoCAD 2012 the Microsoft® Visual Basic for Applications Module is required from Autodesk. This can be obtained from following link.
bentley.sharefile.com/d-s73537ef751045728
For more information regarding this item it can be found in the readme link below:
ftp://ftp.bentley.com/pub/help/bentleyautoplantpandid/081110182en/readme.htm
