| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.11.87(SS6) | ||
| Environment: | Windows 7 (64 bit) & Others | ||
| Area: | Component | ||
| Subarea: | Data | ||
| Original Author: | Deepak Singh, Bentley Product Advantage Group | ||
In OpenPlant Modeler, to modify Stem Diameter of Hand wheel.
In OpenPlant Modeler for hand wheel, a user can modify hand wheel length (HANDWL_LEN) and diameter (HANDWL_OD) but there is no any option to modify the Stem Diameter of the hand wheel. The value of stem diameter is hard coded in the code and it’s dependent on the Wheel Diameter.
communities.bentley.com/.../29122.how-to-add-a-lookup-value-for-a-particular-constraint
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
