| Area: | Detail Center | ||
| Subarea: |
Detail Style | ||
| Original Author |
Sandip Kar, Bentley Product Advantage Group |
While creating drawings, we need to create a gap between the views to make the drawings more readable and more presentable.
This can be done easily by changing the Distance in Detail Style itself.
1. To make Gap / Distance between ( Front/Rear/Top/Bottom) change Dist. Views value by going to Default settings > Partial Views
1. To make Gap / Distance between Main View and the End plate, change Dist. Views value by going to 2D Display > Common > Groups
