How to Show Dimension from Midpoint and Component Dimension as User Label- v8i
 Product(s): OpenPlant Isometrics Manager
 Version(s): 08.11.09.470 (SS5), 08.11.11.87 (SS6) & above
 Environment: Windows 7/8.1 (64 bit)
 Area: Settings/Attributes
 Subarea: Isometric Configuration - Midpoint-Labels
 Original Author: Abhijit Bute, Bentley Product Advantage Group
During Isometrics drawing generation process, Component can be dimension from midpoint and its dimension can be show as user label. Below steps can be used using both AutoPLANT Modeler-OpenPlant Isometrics Manager & OpenPlant Modeler-OpenPlant Isometrics Manager. Check below shown in both case.
  1. Launch OpenPlant Isometrics Manager.
  2. Open "Isometric configuration" Config option
  3. Use "Dimensioning" option from Index present in Isometric Configuration dialog.
  4. Under "Primary" tab, go to option Mid/Endpoint Dimensions & check ON “Enable Midpoint Dimensions”.
  5. Click on “Save”.
  6. Create new User Label “Valve Dimension”.
    Include    IE_TYPE=CT_VALVE_STRAIGHT
    Text   $(DIM1)
    Type   NOTE
    Cell Name   NOTE
  7. Click “Save”.
  8. Generate isometric to review the result.
  1. Open "Isometric configuration" through Project Administrator.
  2. Select Settings option and click on "Create/Modify" option.
  5. Click on “Save”.
    Text   $(DIM1)
    Type   NOTE
    Cell Name   NOTE
  7. Click “Save”.
communities.bentley.com/.../12639.modifying-dimension-styles
Comments or corrections?
