| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX & Higher | ||
| Environment: | Windows 7/8/10 (64 bit) | ||
| Area: | Component | ||
| Subarea: | |||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
In OpenPlant Modeler, bolts and gaskets are designated as construction elements so they don't work the same way as other piping components do. But you can show/hide all the bolts and gaskets in a model with one command.
