| Product(s): | ProSteel 3D Professional | ||
| Version(s): | N/A | ||
| Area: | Detailing | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
The isometric view 1 is not in the list of views in detailcenter.
Problem with data storage in dwg file.
Close the DWG file.
Open the file via menu File/Drawing Utilities/recover
The audit process should repair the file and the isometric view 1 is available then.
