| Area: | Detail Center Standard | ||
| Subarea: | Parts tab | ||
| Original Author: | Steffen Knoll, Bentley Global Technical Support | ||
| Updated By: | Vyanktesh Nama, Bentley Global Technical Support |
Detail Center displays objects in colors grey, yellow, blue, green, or red based on the revision state. Sometimes it is necessary to reset these colors.
1. Open context menu in Detail Center > Parts tab > object list.
2. Go to Service Functions.
3. Choose Reset Revision State.
4. Reload the model in Detail Center.
