| Product(s): | ProStructures (Prosteel) | ||
| Area: | Steel Connections | ||
| Subarea: | Purlin Connection | ||
| Original Author: | Vyanktesh Nama, Bentley Global Technical Support |
In the below image, we can see the Change Connection option is grayed out. In this wiki, we are going to see how we can open place fly brace connection for editing.
Please follow the steps below to achieve this.
1. Open Structural Properties of the supporting member.
2. Go to Modifications > Loglinks and use arrow key switch to Purlin Beam Fly Brace Connection and then click on Edit button.
This will now open the Fly Brace Connection dialog for editing.
