| Version(s): | 08.11.11.616 | ||
| Area: | N/A | ||
| Subarea: | N\A |
Question
When DGN file from ProStructures (Power Product, SS7/8) is opened in pure MicroStation CONNECT edition, it does not recognize ProStructures properties (no Ps attributes), and multiple elements appear wireframe instead of solid. Installing ProStructures Plug-in for Bentley Products (English) x86 08.11.11.xxx (Object Enabler) helps recognizing ProStructures objects only in V8i applications, but does not affect MicroStation CONNECT edition.
Answer
PowerProStructure Objects are not supported directly by Microstation Connect.
If one is opening the files first in ProStructures CE Edition and saves them there, the object are now with added xGraphics and will show up in Bentley View.
For having additional Businessdata content, please use the iModels export function and open afterwards in other MicroStation based products..
| Original Author: | Jitender Singh Sansoa |
